Spohn sway Bar Installation Kit???
Which of you guys are useing this and how do you like it? I see bmr has one to but i am not a welder so i would rather use the bolt on. Also when orderin it asks for Poly Bushings & End Link Sets in 19, 21, 23, and 24 mm which would i need and how do i figure this out? thanks guys
Originally Posted by Blacker
Since you have a Camaro SS, you would need 32 mm for the front and 19 mm for the rear. That is, if you are still using the stock sway bars. Might want to upgrade to the 1LE 21mm Sway bar for the rear. I did and it was worth it.
