Want to know the Effect of Changing Gear Ratios? Look Here First!
Old 12-16-2005, 11:18 AM
Sharpe's Avatar
Originally Posted by Ragtop 99
Absolutely. Gears feel like they make the car much faster, but back to back testing at the track shows the gains are pretty small (.1 and 1 mph) once you have a 3000 or higher stall converter. ... On the street, 3.23s are better for stoplight racing. When I had a YPT 4000 and 3.23s, I could launch really hard on the street.
Wouldn't lower gears (higher numerically, for newbs) would be better for stoplight to stoplight racing? Or, are you saying that you want higher gears for traction reasons?
My real question is for M6 people. I hear that you lose usefulness of first gear with low gears like the 4.10s because the car climbs the RPMs so quickly. Opinions?
I was thinkning about going with 4.10s as my next mod. done headers and cut-outs.
Old 12-31-2005, 03:32 PM
blue02formula's Avatar
For bolt on cars it's a great gear for a M6. I get 22mpg around town to work and back, and 25 on average on the highway going 78mph on avg.
First gear is a treat to play around with, I can mat it and light em up at any speed in first. But yes the revlimiter comes up real quick when you dump it out of the hole.
Old 01-27-2006, 11:36 PM
Golddigger's Avatar
currently own a 98 firebird formula, my mods are LTs headers, slp lid, 3600 stall, with 2.73s, my best time a 12.9. i thinking on changing gears from 2.73s to 3.73s. my conceren is that with the gear change will i be able to lower my time. if yes, how much. thanks.
Old 01-28-2006, 01:39 AM
99Z28camaroman's Avatar
Default 2.73's to 3.73's
I you read all the postings in this thread which I obviously didn't it says if you already have a high stall torque converter you would only gain .1
I gained .3 on my 95 Z28 LT1 but I didn't have a high stall torque converter when I did the gear change. I did get a slight gear whine. I did the shimes 3 times until I got the gears quite enough for me to live with.
I must admit I am a little reluctant to put my 3.73's in 99 Z28 because I don't want a noisey rear end, on the other hand gears cost me $170 high stall is $500!
Old 02-05-2006, 02:26 PM
CarelessAndImprudent's Avatar
Don't know if anyone else has pointed this out yet, but technically...
higher the number = the lower the gear (known as low or short gears)
lower the number = the higher the gear (known as high or tall gears)
The higher the gear, the higher the top speed, but the slower the acceleration
The lower the gear, the lower the top speed, but the higher the acceleration
Old 02-19-2006, 08:59 AM
XzWhiteGhstzX's Avatar
I have 3.42's in my car right now and I know I won't feel a real difference if I go to 3.73's so I want to go up to 4.10's.
I know my gas mileage will go down a little but my car is really only driven around town and makes a couple shore trips so that won't bother me to much.
However how bad is first gear? I never really dump the clutch out of the hole, mainly slip it but how fast does first gear end? And I am on street radials so am I going to have major traction problems? Also will I be shifting into 5th going down the 1/4 mile?
Thanks in advance.
Old 03-04-2006, 04:48 PM
Italiano99's Avatar
heres a stupid question... where on the door panel do I look to see if my car has the 2.73 or 3.23's. I don't know what the GU2 or GU5 code is. Thanks
Old 03-15-2006, 11:09 PM
Roarin_8's Avatar
Driver's side sticker GU2-2.73 GU5-3.23
Old 03-16-2006, 03:08 AM
Italiano99's Avatar
yea got it thanks... there were a hundred codes in there and ya gotta search for it... GU5
Old 03-16-2006, 03:15 AM
MaroZ28's Avatar
sad my low miler doesnt have the sticker....
Old 03-16-2006, 12:29 PM
MaroZ28's Avatar
can anybody tell me what came on my car or how to go about figuring out what came on it?
Old 03-16-2006, 12:48 PM
  #32
Roarin_8's Avatar
If your car is stock, 3.42s
You can also check the gear calculator at the beginning of the page. At 80mph in 6th gear, you should be crusing at 1800rpms with the 3.42s.
Old 03-16-2006, 02:37 PM
  #33
MaroZ28's Avatar
gracias senor
Old 04-03-2006, 07:16 AM
  #34
rob scott's Avatar
i have a a4, 2.73 gear and i was wondering what mph loss i will have if i go to a 4.10 gear? does anyone have a a4 car with 4.10 gears and know what they turn in a 1/4 and what it was stock because i want to run 4.10s?
Old 04-11-2006, 12:51 AM
  #35
Hoss Ghoul's Avatar
3.73's are the highest I would personally go on an A4. I went from 2.73 to 3.73's on my 3rd gen, great difference in feel, kept the car in its powerband, definetly quicker, etc.
4.10's are to low a gear for an auto IMO, you will be pulling close to 4000RPM's at highway speeds. There are calculators that can show you the exact RPM with your tire size @ various MPH. Unless the car is for track only I think you'd regret greatly going with such low gears on an A4.
Old 04-28-2006, 02:59 PM
  #36
blind527's Avatar
I have 3.23's in my car, not sure if I will go to a 3.73 with a 3200 stall. Or just get the stall, based on information people have stated from here. I'll probably still get both, just so I have the gears in.
Old 05-13-2006, 06:25 AM
  #37
autodad's Avatar
did you ever go threw with the gear swap? I only ask cuz i just did a 3400 stall and I don't want to get the gear if it will only net me a tenth.... any track results? thanks, steve.
Old 05-26-2006, 06:00 PM
  #38
blake0024's Avatar
Default 2.73 to 3.73
I was wondering if anyone knew what kind of 1/4 or 1/8 mile changes i could expect by swapping in a set of 3.73s (i currently have stock 2.73s). would it be worth my while to swap?
98 Z28/ slp hood, exhaust cut-out, 30 lb injectors, custom MAS, ported throttle body, smooth bellows, slp air lid and intake, ram air, ls6 intake manifold
Old 05-26-2006, 06:23 PM
  #39
Roarin_8's Avatar
You'll gain more with a stall.
Old 05-27-2006, 12:53 AM
  #40
I did that on my 95 Z28 2.73''s to 3.73's I dropped .3 of a second.
Definatley a worthwile swap the car felt totally different much more responsive no flat spots you won't regret doing gears.
But as has been said you would gain more from a stall.
I dropped .5 from a stall on this car, but it's easier and cheaper to do gears though!
Quick Reply: Want to know the Effect of Changing Gear Ratios? Look Here First!
