Want to know the Effect of Changing Gear Ratios? Look Here First!
Old 06-27-2006, 09:55 AM
  #41
Josh_101's Avatar
Hey that f-body.org site isn't working anymore!
Old 06-27-2006, 10:36 AM
  #42
7 Second Club
ty_ty13's Avatar
bump... just found that out also
Old 06-27-2006, 11:58 AM
  #43
Roarin_8's Avatar
Yeah that bites, says the status= expired
You could always use this one but you can't change the info
https://ls1tech.com/forums/attachmen...chmentid=41066
Old 06-27-2006, 10:53 PM
  #44
Josh_101's Avatar
I like the f-body.org one better, I could mess around with the tire size and different gears when I'm bored.
Old 06-27-2006, 10:56 PM
  #45
Roarin_8's Avatar
I know, so did I but what other choice do we have?
Old 07-21-2006, 11:53 AM
  #46
fiveoformula's Avatar
im 16 and i have a ive got a third gen formula, it has the A4 tranny and 2.73 gears, (its not an LS1 i know... sorry) but i really want some 3.73's because with the 2.73's 0-60 sucks and when im on the highway getting on it, im doing about 70 before i shift into 3rd.... i just want it to do better for street and some strip use (not have second gear go on forever)lol.
so if anyone has any advice, id appretiate it....thanks!
Old 07-21-2006, 03:50 PM
  #47
Hoss Ghoul's Avatar
I had a 1990RS with the 305TBI and went from 2.73 to 3.73, made a real nice difference in performance and driveability.
You can't go wrong with either 3.42 or 3.73, I think if I had it to do over again I'd have gone with the 3.42's to have a little more top end in 3rd gear.
Highway mileage with exhaust/intake/chip/etc and gears was still in the 22-23mpg range.
Old 07-25-2006, 03:41 PM
  #48
Automaticfastic's Avatar
Default Gu5
Originally Posted by BlackHawk T/A
Hmm I have a GU5 and at 2000rpm I am at about ~75-80mph...
ya me too i got a gu5 but my 2000 is about exactly 67 to be exact.
Old 08-04-2006, 01:10 PM
  #49
Roarin_8's Avatar
The gear calculator site is up and running again!!
Old 08-21-2006, 07:03 PM
  #50
staringback05's Avatar
one ? i got the 2.73s and could get the 3.23s for 50$ would that be worth it?
Old 08-21-2006, 07:09 PM
  #51
Roarin_8's Avatar
I wouldn't even bother, upgrade the rear first then choose 3.42s or 3.73s depending if you drive alot of highway or street miles.
Old 09-16-2006, 11:22 PM
  #52
cws T/A's Avatar
T-56 Info http://www.ttcautomotive.com/English/products/t-56.asp
Old 09-22-2006, 08:16 PM
  #53
Emaculate98's Avatar
I need to know what size of gear ring my 98 TA has
Ive got 4.10's with a 71/2 ring but will they fit ive got some information saying i might have a 7 1/2 or a 7 5/8 ring which is it
currently my gears are factory 2.73's
Old 10-18-2006, 08:54 PM
  #54
UMI Performance's Avatar
7wrrw6 4w
Old 10-26-2006, 04:07 PM
  #55
BrianMSmith's Avatar
Higher gear ratio won't help much on the track or strip because the car is going to be running high revs near peak power all the time anyway. Gear ratio doesn't effect power. With a higher gear ratio, you're trading rpm for torque...which means on the street you'll get much better torque across the rpm range (but at lower mph for a given gear and rpm), which will give you better acceleration from 1000rpm to 6000rpm in any given gear...you'll just hit the rev limiter at a lower mph. Higher gear ratio improves the mechanical advantage of the engine over the tires, it's like making a lever longer...you can lift more weight with it, but to lift it the same distance as a short lever you need a longer lever and you need to move it further. Hope that helps.
Old 10-27-2006, 05:11 PM
  #56
Roarin_8's Avatar
When you say higher gear ratio, do you mean numerically higher or lower number?
Old 01-10-2007, 03:35 PM
  #57
SMOKKINU's Avatar
In my 6 speed, cam only car, i got a Dana 60 with 4.30 gears.
99 ls1 ta ws6
11.00 @ 116mph with 100 shot of nitrous and tire.
Old 01-19-2007, 01:51 AM
  #58
95camaro3800's Avatar
I have a 1995 camaro 3.8 auto, and it came with 3.42's from the factory, at least im pretty sure. At least that's what this says: http://tech.firebirdv6.com/general.html. Just wanted to point that out, since it stated in the original post that "your A4 did not come with 3.42's)
Old 01-25-2007, 01:24 PM
  #59
Roarin_8's Avatar
The original post should be "Your V8 A4 did not come with 3.42s I've noticed that smaller motors have more aggressive gearing from the factory. Look at those 4cylinders running 4.56s
Old 01-25-2007, 10:39 PM
  #60
RagnZ's Avatar
i've got a 00 z with a 3400 stall and 3.42's (previous owner installed) but sadly enough those dang m6'ers with 4.10's from a roll are playin the pinks theme song on me......is gears an option i was thinkin bout 3.90's but from what i'm readin i'm not gonna gain much at all if any. most of my races are on the street from a roll, any suggestions for a nay or yay on the gears will be much appreciated.
Quick Reply: Want to know the Effect of Changing Gear Ratios? Look Here First!
