12 bolt moser question
Ok i dont know much about rearends and axles setups if i bought this kit what else would i need like differential, gears just let me know what id have to pick up with this kit thanks.
12 Bolt Housing & Axle Package $1295
(Includes 12 Bolt Housing with brackets, M/E Custom Alloy Axles, new housing ends, wheel bearings, wheel studs, retainer plates)
Several good writeups on the net, don't let it scare you off.
Really easy if the car is still rolling, because you can take your time working on it.
Here's a tip, buy an spare pinion head bearing (the big one) and using a die grinder with a grinding stone in it, open up the diameter so it will slide on and off the pinion without pressing it on. That makes getting the pattern really easy.
