Difference in weight between nodular and aluminum centersections?
LS1Tech Co-Founder
I'm planning to do upgrade to 35 spline axles and a spool, and have been kicking around an aluminum center section. Anyone know the difference in weight?
Originally Posted by GM Muscle
They are actually about 18-20 lbs depending on who's your going with. I'm looking at going with the Strange aluminium center.
cause I heard you could save 40lbs all together on the rear w/ alum. center / lt. wt. spool and a lt wt. housing but when I looked into it was more like 22lbs total.
LS1Tech Sponsor
John, if your going to go aluminum I would get the Moser through studed center. I am going with all light components on my car this winter and I will be runnung the Moser case. part # 3250alu
LS1Tech Co-Founder
KP says the Moser alum. centers are stronger than the Strange ones...
Then again I could gun drill the axles and save the weight that way. Either way I am looking to make stuff lighter but still handle 900+ hp at the crank.
