ring and pinin install procedure
Installing gears is not for the typical backyard mechanic. You need to have the proper tools, knowledge (experience), and patience to properly set-up gears. If you screw it up the gears (which will be easy if you dont know what your doing)will most definatly fail. It worth the $250 to get them installed.
This site should help you.
http://www.fullsizechevy.com/fscu/axletech/
Dude, go for it It's not that hard and it's a good excuse to get some extra tools. One can never have enough tools.
