Does Motive make a 2 series 3.73 for 7.5??
Old 10-18-2005, 11:07 PM
Extinct SS's Avatar
Default Does Motive make a 2 series 3.73 for 7.5??
Anyone know if Motive makes a 3.73 for 2 series carriers? cant find info anywhere for it.
Old 10-19-2005, 08:13 AM
Mike2000Z28's Avatar
Yeah but I think they use a spacer for that size. Check out Summit Racing and get a set of Richmonds "thick" 3.73s they will cost with install kit about $250 after shipping. At Speed Inc. they are a listed here, but I would checkout Summit first.
http://www.ls1speed.com/catagory.cfm.../%20Driveshaft
Old 10-19-2005, 12:23 PM
pman's Avatar
I had my local ring and pinion shop buy and install mine for $505 total. They bought richmond gears with total labor of $250. So all the parts came into under $250. You may want to call local.
Old 10-19-2005, 11:47 PM
silver30th's Avatar
i could not find any 2 series 3.73 motive gears...i ended up having to go with strange engineering
Old 10-20-2005, 12:22 AM
chicane's Avatar
No, Motive Gear does not make that set.
But....... Precision Gear and USGear/Strange does make them in a think set for use with the 3.08 and numerically cases.
I would use Precision over Motive anyway..... only because Percision uses USGear/Strange machinery, which just happends to be the largest OE supplier.
