question for Patrick G.
Old 02-20-2002, 04:20 AM
RGVelite's Avatar
Default question for Patrick G.
YOU RECENTLY GAVE ME SOME ADVICE ON CONVERTERS.
MY QUESTION TO YOU IS THE FOLLOWING. IM GOING TO INSTALL AN MTI B1 CAM. KEEP IN CONSIDERATION IM SPRAYING 125-150 NW WHEN NECESSARY.FRIENDS ARE RECOMENDING ST3500 THEY SAY IT WORKS VERY GOOD ON MOTOR. OTHERS ARE SAYING PRO YANK3400EXTREME BECAUSE OF THE SPRAY SOMETHING ABOUT A LOCK-UP.GIVE ME YOUR BEST ADVICE. THANK YOU SO MUCH
02 TA COLLECTOR EDITION
MAF PORTED ENDS-KN FIPK-PORTED THROTTLE BODY-OFF ROAD PIPES/ SLP LONG TUBES. 12.96/107.4 MOTOR <img src="images/icons/confused.gif" border="0">
Old 02-20-2002, 07:36 AM
Holes02's Avatar
Default Re: question for Patrick G.
I think the Yank 3600 "Extreme" would work well.
Built for nitrous use, but it's slightly bigger then the 3400 which should compliment the "B1" cam as well.
Old 02-20-2002, 08:34 AM
Colonel's Avatar
For no more nitrous than that I might go with the ST3800. Or if larger shots are anticipated on down the road I would go with the PY3600E.
[/Patrick G mode] <img src="gr_images/icons/wink.gif" border="0">
Old 02-20-2002, 08:56 AM
LS1 Tech Administrator
Patrick G's Avatar
Personally, I like the ST3500 best for sprayin' and playin'. It's good for up to a 150 shot witho no problems and is fantastic N/A. If you're crazy and want to run something like a 175 shot or bigger, a larger diameter converter like a Pro Yank 3600 Extreme will have more holding capacity under the juice.
Under a 150 shot, you'll go faster with a ST3500. 100 shot or under, the ST3800 would be even better (just like the Colonel said) <img src="gr_images/icons/wink.gif" border="0">
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 02-20-2002, 10:18 AM
Colonel's Avatar
Yeah, say for a 125-150 shot, if N2O performance was my main goal I would lean more towards the ST3500 like Patrick said, but go with the ST3800 if NA is more important and if you don't mind a little looser converter. <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
