driveshaft trouble
driveshaft trouble
OK I had someone fix my trans and since it came back, at about5000 rpm the driveshaft vibrates really bad... if it was dropped from the car while on the lift, can it be "tweaked" and out of shape?? but it also has a small spot that looks chewed up like its had something slammed up on it will that do it too?? cause its getting real annoying.. and if so where can i get another one??? thanks in advance for any input
tried to rotate it, and didnt work, and im not what you would call set with money and at about $150 a pop for a DS, i guess im gogin to just have to deal with it till i get a new one
thanks for your imput everyone
I would try swapping the drive shaft with a freinds to make sure that was the problem. How tight are the nuts on the u-bolts?(they are not suppost to be really tight)
