low trac. + ABS inop. light after 3.73's
I tried a search but I keep coming up with "no matches found". I just finished installing an Eaton posi and some Motive 3.73's with a solid pinion spacer. The rear set up real well, but now the low traction light comes on then switches to the ABS inop. light. I can feel the ABS cycling in the pedal on brake application too. WTF? I reset the speedometer with HPTuners. What else do I have to do to get this right? Any help would be appreciated!
P.S.
Any ideas on resetting shift points would help too!
P.S.
In the 01, your sensors are at each rear wheel, did you reinstall the wires after you removed the sensors to get the C clips out? The car doesn't care about gear ratios but the speedo and transmission do, so yes you need to recalibrate but it won't cause a TCS light.
Actually, my sensor is not at the wheels, but in the top of the center section. I did re-set the computer for the gears, but I'm still having a problem. The car was driven a bit before the re-calibration was done though. I heard this could throw the ABS computer off. Any suggestions?
