lt1 rear end in ls1
I just did the same swap! You have to remove c-clips and pull axles out. Then swap backing plates. And make sure you use your LS1 axles when you put them back in. DO NOT USE THE LT1 AXLES!! i tried using the LT1 axles and for some reason my wheels wouldn't fit on them flush! Swapped them out with the LS1 axles and works like a dream! Good luck!
Brent
Brent
