Would this affect my top speed.
I'm figuring that right now I could top out at about 195. My questions is, if I were to get a 4.10 gear ratio... Would that lower my top speed? According to the chart, a 4.10 gear ratio in 6th at 6700rpm could take me to 255mph, so either way I would run out of power before gear. Would 4.10's slow me down???
I was under the impression that the higher the gear, the more HP it uses up, kind of like a bike. Even if you have tons of power, wont it still lower your MPH considerably? It should produce less dyno power too, but the curve should change,
I am no expert... any other opinions?
Let's say that it requires XXX HP to top out at XXX MPH. Let's also say that your engine can just barely produce this required HP. Then you simply select whatever gear that puts your engine's RPM at that peak HP level. Obviously too high or low of a gear will put your engine at a lower HP number and you will not go as fast.
thats the real question? lets disguess a real number not a hypathetical one.
Originally Posted by TheAntiRice
the answer is yes
ok no the gear will not lower YOUR cars top speed. going from a 3.42 to a 4.10 would lower the top end if you could redline 6th. BUT YOU CANT. the 4.10 makes it easier to pull threw the gear. and sence the car is aerodynamic, and power restricted. NO YOUR CAR WILL BE FASTER OUT OF THE HOLE AND YOU WILL NEVER SEE THE DROP IN TOP END. if 6th at 6700rpm's is 255mph, you will never get there with your mods, or even close. so gear is not the limiting factor. I have 4.10 in my f-body, and had it well over 150mph just for your personal information
Im with Pontiac on this...I Have 4.10's in my car and have ran close to if not a little over 150...the trade off wouldnt even be a thing to think about..I guess after you get beat by someone you could tell them you could run 250 MPH...and then lets say you could, you better go read one of the 70 threads about Aerodynamics put the 4.10's in gain some performance and not worry about some magic number.....
A higher or taller final drive ratio (gear) will have a numerically lower number, so 2.73 is taller than 4.10
So a taller final drive ratio may or may not affect top speed, or indeed it may have no significant affect at all.
Also when a vehicle is put on a chassis dyno you will dyno the car in a gear with a 1:1 (or as close as) ratio. Meainig that for every one revolution of the flywheel the output yoke on the gearbox (and thus the propshaft) will also turn one revolution. The amount of power being delivered to the rear wheels would only vary thru manufacturing tolorances and frictional loses.
The only time dyno numbers can be confusing is when a high stall torque converter is un-locked, as a torque converter multiplies torque.
As to the original thread posters question, how fast do you want to go? With stock sized tyres and a 6000rpm red line you should see just over 150mph in 5th with the 4.10's, I would assume the car would still pull in 6th, but due to the internal gearing of the 6th gear ratio I do not know how well. Even the C6 Z06 makes it's top speed in 5th and not 6th and it has less weight and more power.
If 1/4 mile and sub 140mph capability are your main goals then 4.10's sound like they should work well. However if you want to see 150mph+ then 3.73 or 3.42 maybe the better bet. However the cost involved may not be justified by going from 3.42 to 3.73
A short final drive ratio will give snappier in gear accelaration but it will hamper high speed work and require more shifting. That's why when I upgrade my 10 bolt I'll probably go 3.08 or maybe 3.42 (I'm auto so it's slightly different) but the principle is the same, I don't want to loose out on the high speed stuff.
with 4.10's 5th gear tops out at 172mph... at 172mph in 6th I would be at 4500rpm and at 4500rpm my car is at peak tq as well as 350rwhp which is pleanty of power to make sixth pull
1st - 2.66:1
2nd - 1.78:1
3rd - 1.30:1
4th - 1.00:1
5th - 0.74:1
6th - 0.50:1
So with a 25.66" tyre and a 4.10:1 final drive ratio 6000rpm in 5th would equal 151mph, the same speed in 6th would be just over 4000rpm but with that 0.50:1 ratio I still think it would struggle to pull much, even with 400rwhp. However I can see ~175mph being possible, but this is all suposition as I have no prove or expericence in this circumstance.
