Stock axle replacement -- Moser or Superior better?
Old 05-02-2006, 11:17 AM
John_D.'s Avatar
Default Stock axle replacement -- Moser or Superior better?
Been prowling around some websites, and searching here, but haven't found anything to definitely steer me to one vs. the other.
Moser is a popular brand, and they say you can send the axle back to be cut and resplined later if you end up narrowing your rear end.
Superior says they cold roll their splines and as a result they're stronger than cut splines.
I don't plan to narrow the rear on my car.
I have 3-channel abs, so reluctors aren't an issue either.
Running an automatic, and a turbo, shooting for around 650rwhp.
Pricing is about the same for both, around $220-$240 for a pair.
Any major pro's/con's of these two brands?
Old 05-02-2006, 03:46 PM
GM Muscle's Avatar
I had ordered both just to compare them. When the Superiors showed up they where all greasy and shitty in some spots and had rust in other spots. When the Mosers showed up, they where pefect. Overal quality of the Mosers looked better and they are also about 3lbs lighter than the Superiors per axle. So I stuck with the Mosers, they've been handling 1.40s no sweat.
Quick Reply: Stock axle replacement -- Moser or Superior better?
