9 inch axle install? help
The 9 inch rear ends arent set up like the normal 10 bolt. Its impossible to have c-clips and a 9 inch as there is no cover to gain access to them. The axles are held into place by 4 bolts on each side of the axle tubes. Hope this help
You need to have the wheel bearings pressed onto the axles before installation too. How about reluctor rings? I suggest calling the manufacturer or finding a good installation write-up before you proceed.
