SLP Gears??
SLP Gears??
Just wondering what you guys think about the gears SLP sells im looking to upgrade to 4.10s and i may have found a good deal on a set of SLP 4.10s also what are the Zexle torsen paddles for??
https://ls1tech.com/forums/gears-axles/412366-rear-end-faq.html
Gears are gears are gears...imo no brand is really 'better' than another. I've had motive, richmond, yukon, moser, they have all been fine.
Check this out Guys would you but the kit from Thunder Racing for 400bucks or would you buy all this for 415bucks?? What do you think is a better deal??
SLP Installation Kit, Ring and Pinion, 1989-02 Camaro/Firebird
SLP Paddle Kit, Zexel Torsen 4 Series Gear Adaptor
SLP Ring & Pinion, 4.10, Gear Set 7.5" & 7.625" Differential
SLP Cover, Differential AAM Cast Aluminum
