Loud noise please help!!!!
I just had 373's installed and everthing is fine and sounds good until i let off the gas and let the car slow down itself and then its a really loud sound like something is rubbing or something but it has to be in the rearend cause it did not do this before i had them installed friday...
Sounds like gears are not set up properly. I cant remember exatly, but I think to much pinion depth will cause gear whine on decel. So I would have them recheck the setup, I dont think it is just right.
where do u go to get something like that checked? or what do u say? i have the same problem (srry didnt mean to steal thread) except i bought the car used so i dont know if there are different gears or anything different from stock
Try and find a place that does standard transmissions not just autos. You could get lucky and find a regular shop that will do it right, but I doubt it.
Rear-end work is not something that comes in everyday. Ask them stuff like backlash, pinion depth, gear pattern..etc. If they say we'll just fix it, take your business elsewhere. Good Luck.
