Why the spacer?
Old 06-26-2006, 09:47 PM
HossZ28's Avatar
Question Why the spacer?
I plan on going from 2.73s to 3.73s so I checked out speedinc and found that a spacer is needed. I dont know anything about the rear ends so can someone shed some light.
Old 06-26-2006, 09:56 PM
keliente's Avatar
Here's a good place to start reading.
https://ls1tech.com/forums/gears-axles/412366-rear-end-faq.html
You need a spacer because you have a 2 series carrier.
Old 06-27-2006, 02:36 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
If you keep the 2-series carrier, you can go with thick gears. That would eliminate the need for a spacer. I found a really nice used 3-series carrier on ebay, and purchased it when I did the swap. That allowed me to use regular 3.73 gears, and I was able to get rid of my tired old 2-series carrier.
