Need ABS Delete for LT1 3 Channel.
I am installing my 9 inch in my 1994 Formula next week. I have 3 Channel ABS on the car and needed to know what I need to delete it, and where I can get it from. I assume I need some sort of block.
Thanks In Advance
Thanks In Advance
We manufacture ABS delete kits for your car. All kits include proportioning valves and all necessary components. If you don't already have a LL solenoid, we have them ready to go for the kits as well. Our kits enable you to completely remove the entire ABS bracket as well as the modulator to remove ~16lbs of weight from the front end.
www.sjmmanufacturing.com/cam_brk_lt1.html Hit the "ABS delete kit" link on the left side of the page.
One part number. You can purchase it as a kit. It all depends on which kit you prefer. 1ABSX1. Check out the descriptions of each to see which you prefer. You want to choose the 3 channel option.
