Decisions....9" or 12 bolt
I know...I know. Been beat to death.
But I am about 24-48 hours away from ordering a rear.
I have searched though, and am not able to find the answers to a couple questions.
1. Opinions/cons/pros of both a 4.10 and a 4.11.
2. Weight differences between 12 bolt and 9" if both are Moser housings??
3. Is the Moser 12 bolt enough to take a 500 RWHP 500 ft/pound car??
4. Stock driveshaft fit into Moser rear ends without modding??
5. Recommendations for a 500 RWHP 500 ft/pound car?
6. How much more parisitic loss does the 9" really have over the 12 bolt?
TIA
TIA
TIA
TIA
are Moser housings?? If I remember correctly, the 9 inch is approx 30 lbs heavier.
3. Is the Moser 12 bolt enough to take a 500 RWHP 500 ft/pound car?? Yes, in an automatic car. For the stick cars I would go with a 9 inch.
4. Stock driveshaft fit into Moser rear ends without modding?? Yes. Both the automatic and the stick cars use the same length driveshaft, and can retain it. You will need a Napa pn# 240-0447 conversion U Joint, as the stock driveshaft has a 1310 yoke, and the Moser rears come standard with a 1350 yoke.
5. Recommendations for a 500 RWHP 500 ft/pound car? I'd go with the Moser 9 inch. I prefer the way Moser bolts the torue arm up to the 9 inch better than their 12 bolt. The Moser 9 inch uses the oem style of using two long bolts. For some reason Moser uses 4 short bolts on their 12 bolt to connect the torque arm, and they have a bad habit of working loose, even with using loctite.
6. How much more parisitic loss does the 9" really have over the 12 bolt? That's good question. We had a T/A that had a Moser 12 bolt, that we swapped it out for a 9 inch. We should of dyno'd the difference... I'd say it's not enough not to go with the 9 inch. Bob
Thank you!!!
Actually looking at the Moser 9" with 3.90's.
With the tire I will be running (26") I would most likely be bouncing off the limiter crossing the traps with the 4.10/4.11.
Thank you!!!
Good deal Curtis.. get the 9" for sure. If I had a A4 Id go 12bolt no doubt. Im going with the S60 because I cant get a ABS friendly 9" with my non-TCS car and the weight between the two isnt enough to make me worry with almost 600rwhp.
