Exciter rings on a 10 bolt
Is it possible to remove the exciter ring off my 4 channel 10 bolt axle and install it on a 3 channel axle? My right side axle has some bearing wear and I have another axle to replace it, but it does not have the ring. Any help would be appreciated.
You can actually find it out by yourself. Just remove the rings from one of your old axles and compare the axles side by side. Removing the rings is not difficult. I used a pry bar to get mine off.
