used gears or not?
Old 04-14-2007, 11:56 AM
speedracer1280's Avatar
Default used gears or not?
I am on a tight budget...money comes easy but leaves easier... i have 3.23 in my 99 30th ann ta...would any of you suggest buying used gears or just asve the money and buy new ones?
Old 04-14-2007, 01:05 PM
BigJoeBob1's Avatar
new definitely, if there is bad pattern on the used ones they will never be quiet
Old 04-14-2007, 01:11 PM
THE CHOP SHOP's Avatar
New all the way. If you use used you need to get things dead on to the way they were run last or they will be noisy.
Old 04-14-2007, 04:56 PM
JEB99TA's Avatar
As cheap as gear sets are, you'd be foolish going with used gears. Once gears are steup in a car, if you put them in another rearend, the true track of the original setup will always be burnt into the gear set and you will have noise.
Old 04-15-2007, 09:57 AM
yeah thats what i was thinking....they'd have to be dead nuts not to whine...thanks....
