1350 u-bolt torque
Old 04-15-2007, 12:20 PM
DuronClocker's Avatar
Default 1350 u-bolt torque
How tight do the U-bolts for 1350 yoke need to be? Want to finally get everything under the car all tied up today.
Old 04-17-2007, 07:17 PM
Rodder's Avatar
heh, just found this post while I was doing a google search. And then remembered I found the spec on Dennys Driveshafts FAQ page last time I had to look it up. It's 20ft-lbs, and they claim that over-torquing is the #1 cause of ujoint failure.
Old 04-17-2007, 08:19 PM
xpndbl3's Avatar
I always go as tight as "feels right" with that small wrench. Don't have to crank on it at all.
Old 04-17-2007, 10:11 PM
I'd heard about cranking down on them too far causing bearing out of roundness and premature failure which is why I posted to begin with, but I ended up just doing what Steve said. Figured a lot of torque wasn't really needed seeing as they don't really have any tensile load applied to them, and the nuts were those out-of-round self-locking type nuts, so I just anti-seized and snugged them up. Thanks for the replies
Old 04-18-2007, 09:14 AM
kapedogg's Avatar
What's the best tool to get on those bolts? An open ended wrench takes FOREVER! I got a craftsman ratcheting wrench but the top of the head was too tall and I couldn't actually get on the bolt.
Old 04-18-2007, 09:39 AM
AW794's Avatar
i used a short 9/16 socket
Old 04-18-2007, 03:30 PM
I used a ratcheting wrench for 2 or 3 of them. There wasn't quite enough room by the 4th nut, so I just used the open-ended side.
Quick Reply: 1350 u-bolt torque
