9" qeustion
9" qeustion
Couldn't find anything with the search. My question is if I by my own center section and get a housing with axles from exotic how will I set up the brakes? Will the housing already have the the mount? Also for the trac control and abs do I have to have somebody set that up off of my ten bolt or just order that with the housing?
The Moser 9" housing comes with the torque arm mount.
You reuse your 10 bolts brake backing plates.
For the ABS and TCS, order the housing and axles set up for it. It is an extra $100.00.
You won't notice any horsepower losses on the street with the nine inch, unless you are talking rwhp dyno losses.
The info found here may help you out. Bob
http://www.exoticperformanceplus.com....html?item=145
