axle swap-any heads up?
whats up guys, im about to swap in a new axle, just wanted to know if there was anything you guys could give me a heads up about, anything to avoid or anything. thanks in advance.
its pretty straight forward. ide recommend getting new fluid obviously and after you pull your axles ide check your seal and bearings to make sure everything is in good working order.
