ok help em choose my gear
ok heres the deal i want u guys to help me i have a 93 formy wiht just a few bolt ons and will prolly only add a few for the rest of her life i want itt to have the hodl u in your seat feeling im leaning on 4.10 or should i go higher i dont care about mpg by the way, remember my car is almost stock
Originally Posted by kezy219
it says u have 4.10s on that link.
You didn't read far enough.
(copied from the link)
The rearend is now back in, we had Moser narrow it 1 1/4 inches per side. Mike at Moser also recommended gun drilling the axles, so we had that done too. They took out 6lbs per axle and it only cost $100, that is a lot of rotating mass!! While at Moser, we did some more calculations and stepped up to a 4:30 rear gear. With the 28" tall tires, and they will grow approximately an inch on the big end, we can run 120 mph at 6000 rpm. Once the new engine is in, this will allow for 140 mph trap speeds at 7000 rpm.
