4.10 gears top end question
does 4.10 take away from your top end and if so where would the car top out at... and another question, if i put heads and cam would it do the 150 or better....
It takes away from your top end.
are you a M6 or A4?
Also, if you get a cam that revs higher, you will still have a decently high top speed, as the 2nd person already mentioned.
are you a M6 or A4?
I have 4.10's and have no problem running 150mph plus if i need to. It all depends on the mods you have. Also if you plan to run top end you might want to increase your rev limiter.
