BMR Torque Arm Question
I just had a BMR Adjustable Torque Arm installed along with a Moser 12-bolt. I can hear/feel a sort of vibrating noise when I get on it (not present when just cruising lightly or coasting, and it doesn't sound like the end of the world, but it is there none-the-less), very hard to describe unfortunately, and I'm trying to find out what it could be and if I should be ok at the track tomorrow.
I was told by a friend that you have to cut the top of the BMR torque arm if you have a Moser because it will hit a back seat bolt if you don't, but I know it definitely wasn't cut. The guy who installed it (well known shop) told me it is the stock torque arms that need to be cut, not this one, but my friend insists it needs to.
If you do need to get it cut, will this be a problem I should worry about at the track tomorrow or should I be ok? Other ideas as to the noise? (sorry I didn't give much to go by)
I'd get the car up in the air, supported by the tires. That way you can see if anything is in the way. Sometimes the seatbelt bolt is in the way, other times the bolts going through the torque arm are the culprit, and need to be removed and installed from the other side. Bob
Originally Posted by BlackScreaminMachine
to clarify, on Moser rears the 1st set of bolt holes has to be cut, otherwise the tq arm pushes out too far, hits the seat belt bolt and throws the geometry of the rear off. My BMR tq was damaged due to it not being cut initally.
Originally Posted by 99zman
i wish i knew this when i had my umi tq arm installed.... im back to stock and happier than ever.... i will never run a aftermarket tq arm again..
I just got my Strange 12 bolt installed and I have mine on the first set of holes on my BMR adjustable TA. I don't have the rear seats in and everything looks great as far as tunnel clearance.
