moser 9" fluid question
i have a moser 9" that i installed last year. I have a couple of hundered miles on it and i have heard that changing the fluid is a good idea.
what do you guys recommend?
also i know that draining it with the plug is not going to remove all of the fluid, but i am guessing it is going to be enough. How much fluid is supposed to go back in the unit after the change?
thanks for your help.
after the break-in period i switched to Lucas 85/140 Gear Oil and it actually quieted down some gear whine i was having in almost every gear, now i can only hear it cruising above 70 in 6th gear.
Edit: I was told by driveline soloutions to use 3 quarts
i had heard 3 quarts also, i guess my problem is that since i am leaving the rear-end in the car, i really have no way of seeing how much is inside......is there any way to keep from overfilling? i just want to avoid fluid coming up through the breather line.
