Choosing which brand to go with for 3.73s
So, the choices are Motive, Strange, Richmond, and GM from what Ive gathered. They all have good reputations so I guess Im looking for the least noisy. Ive heard stories of some bad gear whining, but I know that can also be attributed to the install. Anyway, I just thought Id hear some opinions and suggestions. I have a 2 series carrier on my 02 z28 and I will be getting gears very soon. Thanks
14 Second Truck Club
The 2 series carrier eliminates GM gears unless you use a spacer or change carriers. I would choose Motives at that point.
Also, do a search, gear preference has been covered 1000 times.
I have some Richmonds. They make some noise but if I was to do it again I would get a GM gear. It was my first gear swap so that might have something to do with the noise but I pulled the rear apart 3 times adjusting things to only have the same noise I started with. I moved the pinnion all over the place and had an experienced rear builder help on the 3rd go around.
Originally Posted by staringback05
...i mean all aftermarket gears are going to make some noise....
My choice would be in the following order:
USGear/Strange
AAM (OE GM)
Motive
And yes, it has more to do with the installation than most think possible.
Originally Posted by chicane
That statement in itself, is a gross exaggeration and pretty much is just a simplified opinion/personal generalization... and not at all true.
aftermarket gears make noise...from aam to richmond...
hmm my motives dont sound like the stockers, my cousins richmonds SURE as hell dont sound stock, and my friends oem upgrade replacements dont even sound stock....but all those dont count....right?...
yes, because you know what cars ive ridden in, how many gear changes ive done, and what god has for lunch....
Second, I have Motive 3.90's in my car. With the windows up and the radio off there is no noise at all. From 90 to 0, coast and drive side are both quiet. To say that all aftermarket gears are noisy is completely false. If you were to say that a Richmond was more likely to make noise then many people would agree, but if you take your time with a US gear, Precision or Motive they will most likely be quiet- unless you just get a bad set.
Also, GM/AAM does NOT make a 2 series 3.73 like I said before so that is not a choice for the original poster. GM does it the proper way and uses a 3 series carrier because that is the way it was designed by them. Not that a thick gear is totally bad, but if you are building new rears you are going to do it the right way.
when i said aam that was at one end of the spectrum...if you change gears in your car regardless if its oem or not...its a change....
also, i didnt say they were all NOISEY....i said they make noise over stock, read my post clearer
Like I said previous- My car has Motive 3.90's in it that are dead silent- NO NOISE AT ALL. Over 90% of the time it is in the set up. I know guys who would retail sell gears and have the customer complain of noise, then get them back in the shop and correct the install.
Originally Posted by Raise
once again, how will i know what kind of differential i have?
You could jack up the rear and put the car in neutral. If you turn on tire by hand and the other goes the opposite way you have a Torsen, an open rear(highly unlikely) or a really bad Clutch/Cone unit(also unlikely). If they turn the same way it will be an Auburn most likely, but could be an Eaton if someone was in it already.
my car was stock when i bought it with only 5k miles on it. isnt there a code inside the drivers side door that will tell me what kind of differential i have?
Gee. I dont know... maybe out of the near ten thousand differentials that I have built (READ: not had them built), might give me a little more insight. Ya think ??
Aftermarket gear sets have no more possibility or any greater chance of making noise over that of an OEM gear set... if set-up correctly.
Maybe the cars you have riden in, the gear changes you "had done" (but not actually performed yourself) and what God tasted when he burped... were because of the guy screwing them together... and/or serving lunch at the same time. The majority of all gear noise is a root cause from installation and set-up issues. But you know that all ready... yet you dont count that in your speculative meandering. Do you ??
If a gear set is set up correctly... they dont sound any different than the OEM set you would pull out of it. If you "set them up" and they make noise... maybe you should really think about not giving up your day job.
In all seriousness tho... there are too many variables in the equation to simply blame noise on an aftermarket gear set.
