What bolt holes to use on BMR TA for 9" Install
I'm getting ready to install my 9". Before I install it , I want to make sure the BMR Torque Arm will work properly with my new 9".
I bolted up the stock TA and no issues, as to be expected.
I bolted up the BMR TA and when I used the holes "further out" the bolts went right in but it didn't "align" as the stock TA did. It was more towards the drivers side.
I tried to use the other bolt holes to get the TA closer to the center section and one of the holes aren't lining up.
Check out my pics.
- What is the proper way to get a BMR Adj Torque Arm to work with a 9"?
- Do I have to open up the one hole to get the bolt in?
- When do I tighten the TA mounting bolts, when its in the car?
Check out my pics.
