Moser 12 bolt install Q?
I just got a moser 12 bolt 33 spline, 3.73 posi.....Im using the LT1 setup
The ower before had to cut the bearings off to get his caliper mounts off and forgot to bring the 1350 u-joint clamps.
Question one.
Does it go...
1. brake mounts
2. press on bearing?
3. spacer
Also what bearings do i need? I have a nmber on them but no parts stores around here know what ones to get.
I think it is a 1.531 ID if i remember right and are the housings 3.125 for the OD on the bearing?
Also what part number and brand u-joint clapms do i need
If somebody has pictures of the install of the axles that would be great!
Thanks Jay
Question one.
Does it go...
1. brake mounts
3. spacer
Thanks Jay
yes, install is brake mount (make sure you have it on the correct way), thats not a spacer, its a press ring. you put the pressure on the ring instead of the bearing so you dont f*up the bearing.
i have a bearing number for local parts stores, the bearings from moser need to be ordered from moser ($100) or a speed shop.
the link isnt working, so go to jegs.com and search for moroso 1350 u joint.
i used them on my 12 bolt, worked great!
i dont have pictures but i can walk you through it if need be, just pm me
Well I got all the parts at bears performance next door to my work
They had the bearings and ujoint clamps for 98 bucks total.
Now to press it all in and install the go picture and launh test crazy!
Jay
Jay
