New Gears
New Gears
Im going to be putting a set of 4.10's in my 2002 T/A within the next couple weeks.
my question is, will i need anything else other than the gearset ? ive allready got a Girdle for it. the cars only got 30,000 miles on it so id assume the stock bearing are still good, or do i need replacements no matter what ?
You can use the stock bearings as long as you can remove the pinion bearing without damaging. If you are unsure I would recommend at least picking up a Pinion Kit. We sell them on our website
Jeff.
Jeff.
