3rd member
Old 01-14-2008, 06:57 PM
articz28's Avatar
Default 3rd member
I got a chance to buy a 9 inch 3rd member for $200. Is in good condition with posi and 3:55 gears. But it is a 28 spline axle setup. Will this hold 400 horses or should I wait and find a 31 spline setup. I plan on ordering moser housing and axle package...
Old 01-14-2008, 07:59 PM
EPP
EPP's Avatar
Question
Thats a great deal for $200.00. It should hold 400 hp, the trouble though is it will limit you down the road, and you'll then have to upgrade to 31 spline axles. It's a tough call! Bob
Old 01-14-2008, 08:27 PM
articz28's Avatar
Plans for the car are to go cam-only and a 100 shot. I will not spray out of the hole but from 2nd gear down. So the 28 spline axles should be ok?? And thanks for the help.
Old 01-14-2008, 11:48 PM
Jawsgear's Avatar
Stock axles or aftermarket??? What is this differential equiped with other than the 3.55 gear?
Jeff
Old 01-15-2008, 04:08 AM
EPP
EPP's Avatar
Jeff
He plans on ordering moser housing and axle package. Bob
Old 01-15-2008, 10:45 AM
Jawsgear's Avatar
That answers the question about the axles then, but not the carrier assembly. If it is a used, stock, and weak positraction I would not waste my time and just upgrade to the 31 spline positraction right now. Move forward with the assumption he wants to do it right from the beginning.
Jeff
