Changing Axle Bearings?
Any special tools or tips I should know about?
My car makes a noise from the rearend. I've been told by 3 mechanics its the axle bearings, so I'm going to tear into it this weekend and see what's up with it.
Also, where should I get the new bearings from and which fluid should I put back in it?
Thanks guys
Thanks guys
what rear end stock 10bolt? i got mine at the dealership. had a rearend shop do the bearings. out of what your saying its the bearings for sure. had the same issue.
1 Post
You might want to have someone there that knows what they are doing. I tore into mine this weekend and it turned into a all weekend thing, and tore some stuff up too. You gotta be careful and take your time. But you will need a bearing puller, and bearing installer (can be rented at autozone for free). And you can buy the bearings and oil there too. I think its 75w-90 thats recomended. And some limitedslip-posi additive. If you have never done it before though, I would really reccomend you take it somewhere to have it done.
I have some cheap 75w-90 with LSD additive laying around, but I may go with some better stuff for now.
LS1TECH Sponsor
Since the axle bearing rolls directly against the axle the axle itself is usually damaged. The axle acts as the race for the bearing. There are bearings called "relocator" bearings that move the bearing and seal as an assembly outward but they always leak.
We typically charge about 1.5 hrs to replace both sides. Other than just ordinary tools, you'll probably want an axle bearing service kit along with a slide hammer to get them out.
You should be able to diagnose exactly which bearing is making the noise with a mechanics stethoscope if you jack the car up and have someone give the car some throttle while in gear. Just make sure you support it under the rear itself so the tires don't rub against the bumpstops. If the noise is in the center of the rear just replace them all, otherwise the axle bearings are fairly easy to replace without tearing into the assembly of the rear itself.
-Jonathan
-Jonathan
-Jonathan
-Jonathan
I got the axles out (1 hour job at most, big deal)
But before I took them off, I had the rotors off. So I was turning the axles while still in the rear, and I could hear the same noise as before. This was while the driveshaft was NOT turning only the axles and whatever they turn inside the diff.
The axles don't have any grooves in them either.
Jeff
It increased with speed but after about 30mph the noise was constant. You can hear it almost immediately when taking off.
It was pretty low on fluid and had quite a bit of metal shavings in it.
