Just installed my S60
Old 03-17-2008, 09:24 PM
transam69230's Avatar
Default Just installed my S60
Got my S60 in over the weekend, and man does it look huge under the car. Hopefully it is the last rearend i will have to buy for the car. Didn't really have any problems at all everything went pretty quick, i even broke it in a little on the jackstands in the garage (weather not so nice in Mn yet). My bolt in LCA relocation brackets from BMR bolted up perfectly as well if anyone was wondering if they would work with the S60. I was even able to get the LCA in the bottom hole this time, maybe i can cut my 60' to a 1.50 on spray this year. Still have to do a few more heat cycles and change the lube, and it will be good to go. I will post some pics when i get the car back up in the air for the lube change.
Old 03-18-2008, 11:00 AM
omcar's Avatar
Congrats you should get into the 1.5s 60' since I run pretty much the same E.T as you (n/a) and i have a 1.57.
Old 03-18-2008, 11:26 AM
kenSS's Avatar
i didn't have any trouble with mine either, great looking rear, lol. i thought the lca brackets would work.
