Rear end installation leaving E-light on?
Old 03-19-2008, 11:19 AM
jebuzws6's Avatar
Question Rear end installation leaving E-light on?
Well I had another 10bolt installed by my dad's mechanic since my old rear was all mest up on my 02 T/A. The rear sounds better and runs great I just have a little problem where the E-brake light turns on after you start to drive it and it just stays on. I'm wondering is it just a sensor a little loose that I can plug in and fix myself or do I have to take the car back to the mechanic so can put it in right? .. thanks
Old 03-19-2008, 09:11 PM
jebuzws6's Avatar
ttt.......
Old 03-19-2008, 10:43 PM
CW00BlackTA's Avatar
Check the sensor plugs at the rear wheels to make sure they are in correctly. Also, check to be sure the cable ends are installed correctly.
