ford 9" and 12bolt for 96t/a help with info on these
i was told im going to blow the r/e cause of the power im going for.so i was wondering if some1 can gime some info on these on how pricey this is and are things going to line up after installing then.im going to be running a cam and a 150 shot with d/r.i was thinking of not using the nos off the line so i dont have to go threw all the drama with the rearend like putting a window switch in or something ?????? please help cause im not a mech.and i only no what i've read or herd.also how bout a ls1 rearend is that any good?
thanks alot for the info
The LS1 rear is the same pos as the one in your car.
Check this link out, assembly instructions also shown further down on this link.
http://www.exoticperformanceplus.com....html?item=145 Bob
