ABS inop light remedied
Rather than unsolder the LED lamp from the instrument cluster, I painted it high-temp black using a brush. I also stuffed some electrical tape between the lamp and the lense. Worked effectively, can't see teh light at all. Just an FYI....
I did some searching here and found a thread where someone said to jump terminal 7 and 12 together at the pump and it will close the loop and keep the light off. Might want to search before trying b/c I might have the wrong pins?
