moser torque arm bolts what size?
Sorry to revive this thread but I need some torque arm bolts for my moser 12 bolt and I'm a dolt when it comes to this stuff. Does anyone know where I can order the right bolts from online? Thanks.
Its not hard to figure out. Go to Lowe's or Home Depot's hardware section. Find the Grade 8 bolts. You will need 1/2" x 13 bolts. Moser ships them with 1" long bolts but if you are running a after market torque arm I would recomend a 1 1/4" or 1 1/2" long bolt because the aftermarket TA material is thicker then the stock one. Also buy matching washers and lock washer, again make sure they are grade 8. Use lock tight and don't be scared to put the purse down and torgue them down tight. You see lots of post were people can't keep these bolts tight, I have had no issues with mine.
