New 4.10s quiet under load but loud on decell, why?
Old 05-24-2008, 10:12 PM
mvvette97's Avatar
Default New 4.10s quiet under load but loud on decell, why?
My buddy and I put a new set of motive 4.10s in my car. They are quiet while under a load like driving up a hill but when I push the clutch in to slow down they whine pretty loud. We had the pattern good and everything. We ended up with a .035 pinon shim and set the backlash to .008. It didn't seem loud at all when we got done with it but since the install I have put about 150 miles on it with no launches or anything, easy driving. What is the common problem that will make them whine while coasting?
Old 05-24-2008, 10:42 PM
CW00BlackTA's Avatar
You have to check the pattern on both sides of the teeth. It has a different contact patch than for acceleration.
Old 05-25-2008, 12:17 AM
mvvette97's Avatar
well I was just reading that the motives I bought are the noisey set So that sucks. I have a good used set of GM 4.10s so maybe I would be better off installing them
Old 05-25-2008, 01:06 AM
LS184's Avatar
my 3.73's whine big time whn decelerating 2
Old 05-25-2008, 01:09 AM
mvvette97's Avatar
Mine were fine for a while but they just started doing this. I think I'm gunna take it down to the shop tomarrow and pull the cover and have a look at it.
Old 05-26-2008, 07:33 PM
johnnydje's Avatar
Under decell means the pinion is shimmed to deep,recheck it.
