Stock "steel" D-shaft & 9" M6??
Old 06-05-2008, 02:44 PM
LM97Z's Avatar
Default Stock "steel" D-shaft & 9" M6??
who is running them & how are they holding up, i'm running an aftermarket non adj. torque arm, I've heard they will be shorter then with the 10 bolt.
Old 06-05-2008, 05:50 PM
EPP
EPP's Avatar
The stock steel and aluminum driveshafts both tend to break when exposed to hard launches. If you are running sticky tires, you should consider an aftermarket driveshaft. Bob
