gears (Help)
gears (Help)
I'm change out the bearings on my stock axle with 3.23. Now i worried that my gears are going to howl because when removing the c clips i took off the bearing caps the gears move forward,but i put the caps back after noticing them move.Can i just tighten the bearing caps and will the gears be ok????
