grrr.. rear end noise
Old 07-05-2008, 08:24 AM
NavyBlue01's Avatar
Default grrr.. rear end noise
well my rear has been making noise since i put a auburn LSD in it i never changed the bearings it came with ) so i ripped it out bought new bearings and cups changed it out added gm lube and valvoline 80w90 test drive sounds great no problems 300 miles later noise is back.. wtf! what is my problem?!?!?
Old 07-05-2008, 10:15 PM
NavyBlue01's Avatar
well i took her out for another spin tonight and it only makes the noise when its warmed up before it did it all the time but tis the same exact noise that i had before..
Old 07-07-2008, 09:17 PM
michaelg589's Avatar
I also have an auburn LSD. makes terrible noises. that mixed with my whining Motive 3.90s, wow. my rear just sounds AWFUL. I'm not exactly sure what the problem is. I've used three different types of gear oil.
When the gears were first installed... conventional oil with limited slip additive was used. After being broken in I used Royal Purple's 75w-90 wihtout limited slip additive (which i didnt leave for very long). I am now using Lucas heavy duty 85w-140 with lmited slip additive. and it is NOISY.
Old 07-08-2008, 11:27 AM
Jawsgear's Avatar
Did you use positraction additive in addition to the oil? Also, what brand of oil did you use?
