s10/sonoma gears - same as fbody rear end?
Old 09-21-2008, 09:28 PM
jfman's Avatar
Default s10/sonoma gears - same as fbody rear end?
I found some factory 4.10 and 3.73 gears out of a 96 s10 and a 97 sonoma. Can I use those in an ls1 rear end? are they the same?
Old 09-22-2008, 06:47 AM
omcar's Avatar
ring and pinion should be 7.5" and should fit...
Old 09-22-2008, 10:48 AM
99NMB's Avatar
Yes you can use those gears, ive got a set of OEM 3.73's out of a S10 in the rear of my car.
Old 09-22-2008, 12:26 PM
jfman's Avatar
Ojk will it fit a 2 series ls1 rear end as well?
Old 09-22-2008, 12:54 PM
zx9rgreen's Avatar
with a ring gear spacer..........Some of the 5 speed trucks were sold with a 8.5" rear end also
Quick Reply: s10/sonoma gears - same as fbody rear end?
