Gear selection help!?!?
Old 10-05-2008, 06:24 PM
BADBOYZ28's Avatar
Default Gear selection help!?!?
I'm currently running a Moser 12 bolt with 4.11's. I have a TH-350 and on nitrous I'm running out of gear before the 1/4 mile finishes. I'm currently spraying a 200 shot out of the hole. I know if I go to a 3.73 I'll be ok. But if I plan on spraying a 250 or so will I once again run out of gear??
Old 10-05-2008, 07:11 PM
SS1875's Avatar
How tall of a tire are you running with the current setup?? that might be something you would/should consider changing as well, not just gearing.
Old 10-06-2008, 08:01 AM
BADBOYZ28's Avatar
I'm running a 28x10.5. That about all I can fit under there cause as it is its a very tight fit.
