Go Back   LS1TECH > Gen 5 Camaro 2010-2011 Forum > Gen 5 Camaro Drivetrain Tech
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 04-29-2012, 12:00 PM   #1
LS1Tech Sponsor
Garage is empty, add now
Trader Rating: 2
Default Gforce1320 Fab IRS 9" Install
We installed one of our fabricated 9" IRS rear ends in a local customer’s car a few days ago.
Brad (Tornado SS) was starting to get some gear noise from his rear and decided to replace the entire rear drivetrain with Gforce Engineering parts.
He has some pretty big plans down the road and wanted the strongest rear so he wouldn’t have to worry about it later.
We talked with him about his goals which were streetable manners, the ability to go on road trips and the occasional track thrashing and he also wanted something that would be plenty strong enough to later handle a supercharged engine.
We ordered up a Strange Engineering pre-built Pro Iron pumpkin with 4.11 gears and a Strange S-Trac 35 spline posi.
We also went with a Dyno-Tech 3.5" Aluminum slip style driveshaft for super smooth highway driving.
Once everything came in and got built we got to installing everything.
We actually installed 2 9" kits this day and both in Orange Camaro!
The other one we took the 9" kit out and did a big bearing up-grade and installed a new set of 3.70 gears.
Not bad, 2 9" kit installs in one day.
Our 9" kit bolts in so easily that anyone with a lift can do one in half a day with nothing more then regular tools.
First up was getting the cat back and stock driveshaft down and out of the way.
Here is the stock driveshaft compared to the new Dyno-Tech 3.5" aluminum shaft.
The stocker weighs 24 lbs and the Dyno-Tech shaft weighs 15 lbs for a 9 lb weight savings.
You will notice the Dyno-Tech shaft does not use any rubber couplers or a cv joint on the front.
It has an internal slip shaft assembly that allows it to move in and out with the suspension travel, this type of shaft provides a very smooth and vibration free ride with our 9" kits.
We can also do this shaft in a 4".
And now out with the stock center section and axles. Now we can bolt all the new components in.
The new axles and assembled center section ready to bolt in.
We start by installing the new outer stubs and then the axles, once they are installed you can raise the center section up in place and bolt the axles to the inner stubs.
You simply raise the center section up into the OEM mounting locations just like you would the factory rear.
Our 9" housing comes with a fill bung so you can easily fill it with lube after install.
Next up is installing the driveshaft.
You bolt the supplied front adapter on first.
You need to push the heat shield up a bit but the driveshaft will bolt right in with all the factory heat shields in place.
Next up is hanging the cat back up.
Brad had a Borla cat back and it fit perfect with the 9"!
Back on the ground all done in under 3.5 hours
__________________
Gforce Engineering
Home of the LIFETIME WARRANTY
www.gforce1320.com
email: Gforce1320@gmail.com
316-260-8433
The leader in IRS Drivetrain Technology
Gforce Engineering is offline   Reply With Quote
Old 04-29-2012, 02:05 PM   #2
Grumpy Bastard
Gunslinger09's Avatar
Trader Rating: 0
Wish I had the $$$ for this set up.
__________________
2010 2SS
Black/Inferno Orange
Gunslinger09 is offline   Reply With Quote
Old 06-10-2012, 02:23 PM   #3
2010 Chevrolet Camaro
silver2010's Avatar
Trader Rating: 0
Mine's on order,hee-hee! Can't wait to get this badboy in so I can beat the hell out of it.
__________________
2010 2SS Camaro.A6 Va. Speed built 427 stroker
Shawn Miller built 427 stroker at 1130hp..
silver2010 is offline   Reply With Quote
Old 08-20-2012, 06:48 PM   #4
GFORCE1320's Avatar
Trader Rating: 15
Send a message via MSN to GFORCE1320
Quote:
Keep us posted on your build, I'm looking forward to seeing it hit the track!
__________________
Gforce Engineering AKA GFORCE1320.com
403ci LS2, Dart CNC 225's, direct port, TH400 & 9" Chance Converter
GFORCE1320 Level 2 HALF SHAFTS and stubs
9.41 @ 144mph, 1.41 60ft on the spray
Proving the stock GTO IRS can hang with anything!
Fastest OEM IRS GTO in the USA
GFORCE1320 is offline   Reply With Quote
Old 11-16-2012, 05:58 PM   #5
2002 Chevrolet Camaro
Trader Rating: 47
Send a message via AIM to Stangkilr
Such a nice setup I just dont want to spend that for a rear end...ill go solid axle for that.
__________________
2010 Camaro SS | LQ9 6.0L | TH400 | G-Force 9 inch | X275 88mm Precision | E85
2013 Camaro SS 1LE | IOM | stock
2005 GMC CCSB-Matte grey metallic, 2/4 drop, KMC slides
http://www.facebook.com/StangkilrProductions
Youtube "stangkilr99"
Stangkilr is offline   Reply With Quote
Old 12-07-2012, 09:54 PM   #6
LS1Tech Sponsor
Trader Rating: 2
Quote:
Glad we convinced you to go with the Gforce 9".
I'm looking forward to the install
Thanks
Chris
__________________
Gforce Engineering
www.gforce1320.com
316-260-8433
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
9, axles, car, custom, dynotech, end, engineering, force, irs, mounting, parts, powered, rear, search, strac, strange, stub, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
