Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
DIY: 4L80-e into 5th gen camaro.
Old 03-26-2013, 08:20 PM
No Hope's Avatar
I've been banned from Camaro5 3 times. When not properly medicated I'm an obnoxious mother ******. Even with medication I'm still an *******.
That's a quote from my mother by the way.
Nice work DietCoke.
Old 12-30-2014, 05:29 PM
DietCoke's Avatar
Here are 3 cal files for the optishift that I used mostly.
Drag strip cal for WOT lockup and ~7100 shifts (you may have to adjust MPH based on your HP, mine was just right for a 650hp car running bottom 10s.)
Street drive cal with ~7000 rpm shifts
Dyno cal so the car will lockup in third on a dyno and not kickdown to a lower gear.
I've given these to a few people by request, they may be a good starting point for someone here.
Also, I apologize but the pictures are long lost to time. Not sure what happened but they are gone
File Type: zip
Old 01-05-2015, 09:40 AM
pancherj's Avatar
Awesome! I can use those files as a starting point. Really appreciate all your help in this thread and via PM's.
Old 01-12-2015, 04:06 PM
moiy1983's Avatar
what software is needed to open this file?
Old 01-12-2015, 04:31 PM
DietCoke's Avatar
Optishift/US Shift software. It comes with the controller, and you can download it from the website too.
Old 01-12-2015, 04:40 PM
moiy1983's Avatar
Dietcoke is there any chance you still have pictures of this thread?
The following users liked this post:
fastsspr (07-15-2020)
Old 02-12-2015, 12:47 AM
Jablowme's Avatar
id be interested also
Old 08-03-2015, 08:37 AM
minnnickc's Avatar
Default Cant See your Pics
Hi My name is Calvin, about to do this swap in my 2013 camaro and my buds 2012 camaro but we cant seem to get your pics from your doc to load. Was wondering if there was any way of emailing this info to us?? camarorlz2013@gmail.com Your doc looks to be very good. Thanks
Old 08-03-2015, 11:25 AM
pancherj's Avatar
Hey Calvin. Diet may chime in here, but I can probably answer the question for him. I have chatted with him quite a bit while doing my swap. The pictures no longer exist. He had them saved on a drive, and they are gone. If you have some specific questions, just throw them up here and I will do my best to help you out. The swap is pretty straight forward if you are coming from a manual car.
Old 08-06-2015, 01:51 PM
DietCoke's Avatar
What he said. The pictures were lost, disappointing.
Old 10-07-2015, 07:15 PM
Motown 454's Avatar
If you guys are talking about the shifter mods I have the pictures. Send me your e mail and I can send them to you.
The following 2 users liked this post by Motown 454:
Juan_1320 (03-24-2020), mclasl1969 (01-21-2021)
Old 11-19-2015, 09:40 AM
  #32
lugnutt's Avatar
Default Shifter Gate
With stock shifter...
How does it to shift 1 2 3 OD? I'm only seeing A and M.
Attached Thumbnails DIY: 4L80-e into 5th gen camaro.-10-13-20camaro-20shifter-20-372x249-.jpg
Old 11-19-2015, 10:20 AM
  #33
DietCoke's Avatar
D is OD and M is 3. If you file away the stop inside the actual shifter mechanism, it will go down to 2 and 1. When you find the 1 position, epoxy/jb weld a new stop on there. Look in the area where the detents are on the shifter, and you can see that there are already detents for more then the gears that is uses from the factory, it makes it really easy to modify.
Old 11-19-2015, 09:17 PM
  #34
lugnutt's Avatar
Awesome, sounds simple enough! Thanks
Old 02-27-2019, 05:57 AM
  #35
5thgenJJ's Avatar
I know this is old tread. I need pics of the notch for the sensor.
Old 03-23-2020, 10:44 PM
  #36
Juan_1320's Avatar
You happen to have the picture of this set up still bud
Motown 454 (03-23-2020)
Old 03-23-2020, 11:06 PM
  #37
Motown 454's Avatar
Default Shifter mods
I think I still have them pm me your e mail and I’ll get them to you.
wayne
Old 03-24-2020, 01:07 AM
  #38
Juan_1320's Avatar
wayne
Juan.enriquez34@yahoo.com
Old 03-24-2020, 07:45 AM
  #39
DietCoke's Avatar
My copies of the pics were lost when photobucket **** the bed back in early 13. Sorry guys. It's not that bad a job though.
Quick Reply: DIY: 4L80-e into 5th gen camaro.
