Gen 5 Camaro Drivetrain Tech Clutch, torque converter, rear end, axles
Don't let this happen to your slave cylinder.
Old 11-05-2014, 06:10 PM
SNLPerformance's Avatar
Default Don't let this happen to your slave cylinder.
It’s no secret that the latest generation of slave cylinders GM has been putting in their performance cars have drawbacks. While the newer slave cylinders did much to alleviate some issues the older units had they actually have a much more severe issue to deal with.
Many of the aftermarket companies are blaming the entire bearing assembly for failure. Upon research, we’ve discovered that the bearing itself isn’t the issue it’s the plastic piece upon which the bearing rides. This piece, when hot enough, disintegrates and causes some pretty catastrophic failures. This not only kills the slave cylinder, it also almost simultaneously kills the clutch in the process.
Here is a perfect example of this issue that happened to a Gen 5 Camaro. In this picture you can see the black plastic bearing support got too hot and failed causing the release bearing itself to eat into the support until it melted to the center part of the slave assembly. After this happens the clutch will not disengage because the release bearing will not move, also in this case it melted the internal seal causing the hydraulic fluid to soak the clutch assembly and cause it to fail as well.
This is the exposed plastic bearing support that retains the bearing on a new slave cylinder.
After discovering this weak point of the slave cylinders in all manual trans C6,C7, Corvettes, Gen 5 Camaros, 1st and 2nd Gen CTS-Vs, and G8 GXPs we developed a billet steel replacement for that plastic bearing support. The OEM on the left and the new billet steel on the right.
This simple upgrade not only takes the weak point out of your OEM slave cylinder it also has tighter tolerances then the OEM piece which helps reduce the amount of bearing movement that is typical at high RPM shifting and rapid gear changes. What does this mean for you? A dependable hydraulic system that doesn't require you to re-engineer the system and measure for setup height, etc. like the aftermarket replacements out there and still allows you to actually abuse the vehicle at high rpm without failure.
Another added bonus is that in a few years when your slave wears or the clutch is getting a replacement, simply remove the billet support from the old slave and reinstall on the new unit!
If anyone has any questions just let us know, this unit works with every single aftermarket clutch available as well as all OEM clutches! It's a MUST HAVE for anyone with these types of slave cylinders!
Old 11-06-2014, 11:06 PM
CAMSTER's Avatar
Default shifting quick...
Good catch and problem solver rite there as well, just a quickie any possibility of getting one made out of aluminum...
Old 11-11-2014, 10:52 AM
CamanLS1's Avatar
How do you get the plastic bearing out? I tried pulling on mine, but didnt want to pull too hard.
Old 11-13-2014, 06:27 PM
Using a flat head screw driver and gingerly prying on the back side of the silver retainer on the nose of the slave cylinder will release the assembly. Just be careful to not damage the retainer. If you purchase a upgraded bearing assembly we send detailed instructions with it.
Old 09-15-2015, 01:21 PM
Just wanted to post a picture of what can happen to the original bearing support. This picture was recently posted by "rpmextra" on the Corvette forum, after he had a hydraulic failure. This was the end result.
File Type: jpg
Old 09-30-2015, 05:04 PM
stevieturbo's Avatar
Is the bearing seizing that causes that, or does it just happen even with a good bearing ?
Presumably the bellows is to try and keep the dust from getting inside ? Does that actually help with the dirty fluid scenario ?
Old 10-09-2015, 04:23 PM
It's the support that fails. The support cracks from the heat, and constant pressure that it deals with. When the support cracks, the pressure from the clutch assembly pushes the release beings through the support, and melts it to the salve. This then causes the seals to melt as well, which can also destroy the clutch with fluid contamination.
The dust boot helps, but the fluid will still get contamination over time.
Quick Reply: Don't let this happen to your slave cylinder.
