A close look at the LG Motorsports Gen5 Super Pro Headers and Exhaust
Hi guys,
The Corvette guys all know me, LG Motorsports, and the layout of our Corvette systems so I thought I would spend some time to high light the choices and features of our LG Super Pro Headers for the Gen 5 Camaro.
Ease of Install
We learned a long time ago to make the system work, it needs to be easy for the user to install. So like our Corvette systems we made this as simple of a bolt on as you can get. All of our kits come complete from engine to mufflers or with mufflers and tips included so all you have to do is bolt it onto the car. Fittings slip together for the smoothest connection between pipes. This also makes our cats replaceable in the event of damage or you want to swap to an off-road setup for track use. The only cutting you would have to do, would be removing the stock mufflers if you want to use them with our kit as GM welded the OE system together complete from the manifolds back.
Configurations and Options
We offer our system in one of four different setups.
1. Full system with out cats, without mufflers
2. Full system w/cats and without mufflers
3. Full system w/o cats and w/mufflers
4. Full system w/cats and with mufflers
All systems will come with off-road pipes included at no charge even for cat'd systems. All systems come with clamps, hardware, extensions, and now GM gaskets as well.
Features
Also a new feature on the Super Pro line is our merge collector with fire cone.
All LG Motorsports header kits are covered for the lifetime to the orginial owner against any defect or issue. Of course damage by accident is not covered.
MUFFLERS
Our LG designed mufflers are fully polished stainless steel. These also a full 3" throughout and end with a 4" double walled slash cut tip. Lightweight and combined with a straight through design give you little back pressure with a deep American V8 sound!
TAKE A LISTEN!
https://www.youtube.com/watch?v=-CZbQsTpezI
2010 A6 L99 Camaro before and after full LG System and Dyno tune STOCK AIR BOX AND FILTER!
2010 M6 LS3 Camaro before and after full LG System and Dyno Tune
As always, please feel free to ask any questions or comments.
Anthony
LG MOTORSPORTS
972-429-1963
anthony@lgmotorsports.com
Ease of Install
Features
- 1 7/8" Primary size
- 3" merge collector with fire cone
- Full 3" mid section
- 3" high flow Siamese X pipe design
- Connects to OE or OE replacment mufflers with included 2.5" adapter
- All wires, hardware, extensions and GM gaskets now included
- High flow optional 200 cell metal matrix catalytic converters
- Off-road pipes included no charge on cat'd systems
- 35+ RWHP GAIN!
- Up to 47 lbs of weight REMOVED!
- LifeTime Warranty for original owner
MUFFLERS
TAKE A LISTEN!
Anthony
LG MOTORSPORTS
972-429-1963
