BMR Releases New Product: Adjustable Lower Control Arms for 5th Gen Camaro - TCA029
BMR Suspension
Adjustable Lower Control Arms for the 2010+ Camaro and Pontiac G8
Increase rear camber adjustability, reduce suspension deflection, and maximize rear cornering stability with a set of Adjustable Lower Control Arms from BMR Suspension. Superior to the factory stamped steel arm, the BMR Control Arms are constructed from heavy duty 2” square tubing and internally-gusseted laser-cut mounting plates. The BMR Adjustable Lower Control Arms (TCA029) feature low-deflection polyurethane bushings, reinforced sway bar mounts, and massive 1-1/8” CNC machined double adjusters to provide maximum camber adjustment for lowered vehicles. Installation time is only 3-4 hours. Available in black hammertone or red powdercoat.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email sales@bmrsuspension.com, or contact them at BMR Suspension, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
LS1Tech Premium Sponsor
These are what all the 2010+ Camaro guys are going to need to be able to run the Weld wheels. We worked directly with Weld themselves to design a part that would allow for the fitment of there 17" wheels on a newer model Camaro.
We are currently building a good size batch right now out in the shop so place your order while we have them in stock.
__________________
Glenn ***
Sales Tech
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
